Re: quick start ?
What I do is pump till rock hard, advance throttle (I have a seperate throttle advance, but you get the picture), turn key to get motor cranking, and then apply choke if need be. Mine usually starts without choke, but other motors I have had need choke. Once running, bring the throttle back down so it is running at around 1000-1200 rpms. Mine will not cold start without the throttle advanced. Let it run a few minutes at high idle to get everything good and warmed up, and have a good ol' time.
