Quick Silver 3000 trim switch repair
DennisP
Based on information from some previous threads, I was able to disassemble my control (QuickSilver 3000) and get to my trim switch (On a 3.0L Mercruiser). Thankfully, I found a broken wire which cured my problem. However, in the process of trying reassemble the throttle lever, I'm off, position wise, and the more I have dealt with it the more confusing it gets. I would guess if I knew the position of the cable in the back when it was in neutral that might be a starting point. Any suggestions? Thanks..:confused:
