eddyandrehab
- Jul 1, 2010
- 9
Question. As you can see in the pictures, the hull appears to be twisted. I'm not equipped to twist it back. I'm obviously not going to be racing her, this is a fishing boat. Do I need to be concerned with it?
Your boat has seen some rough times. The bow looks like a boxer that has one fight too many. The torqued hull should not be a problem for your use; slow safe going to a fishin hole.
You might be able to go with large "L" brackets bent to fit the hull tighter..
If you want to leave what you have,,, I have seen rod holders(storage) mounted to them that looked fairly good and were darned handy.
