I just tonight obtained a 200 Mercury 20HP Model 3069467. It appears in exc condition. I believe that it is a 1971 No sure<br />Checked bottom unit, (no oil) appeared to be greese in there. Could there be instead of oil?<br />There are two screws i presume to fill at the bottom and force out the top> Is that correct?<br />Besides the top screw there is a small flat head screw. What is that for?<br /><br />On the skag there are two real small holes. What are they for?<br />There is two crome like disk located on the bottom unit about half way up. What are they for?<br /><br />Motor looks as if it could be converted to electric start by adding a starter. Is that correct?<br /><br />I have no owners manuel or repair manuel and no library to obtain information from so any and all information would be an asset. Need to determine if motor is good before contract to purchase is made. Motor appears in outstanding condition as for as appearance is concerned. paint still on the original prop.
