1995 SeaPro 3.0lx Alpha I GenII
Bought his boat about 4 years ago and it had a...lets say lack of maintenance problem. I have gone through it and had used the boat successfully for the last three years. Aboyt 10 day trips a year. This year on the 1st voyage the motor made a strange grinding noise while turning so after some research I think its a gimbal bearing. Other than that the boat ran great and did not leak.
Today I pulled the outdrive and found this:
Where did the water come from? I tasted it and it seems to be fresh water? I only run the boat in salt water. I also run the motor on muffs when I get home. I did not start cleaning it yet in case you guys wanted any more specific pictures. The bellows look ok, they have water in them now and after moving the gimbal abound it does not seen to leak out. Could this water intrusion be from the obvious gasket failure in the final picture? That thats the water ump line right? The gimbal bearing turns freely with a little rough vibration so I guess its shot.
What would you do next?
Found some spell it like "gimbel" so you can search it too...
Thanks!
![DSC_0413.jpg](http://img.photobucket.com/albums/v88/icantdo55/DSC_0413.jpg)
![DSC_0412.jpg](http://img.photobucket.com/albums/v88/icantdo55/DSC_0412.jpg)
![DSC_0408.jpg](http://img.photobucket.com/albums/v88/icantdo55/DSC_0408.jpg)
![DSC_0407.jpg](http://img.photobucket.com/albums/v88/icantdo55/DSC_0407.jpg)
![DSC_0406.jpg](http://img.photobucket.com/albums/v88/icantdo55/DSC_0406.jpg)
![DSC_0415.jpg](http://img.photobucket.com/albums/v88/icantdo55/DSC_0415.jpg)
Thanks!
