ShoestringMariner
Thread starter- Joined
- Apr 18, 2015
- 1,605
Hey everybody I’m working on a 1986 60 hp VRO. J60TLCxx . I have rebuilt the carbs. Currently working through replacing all the fuel lines.
I think I found what killed this motor, the lower carb was full of oil. The fuel line just inside the connecter was totally plugged solid with crap, which is what I figure cause the oil to be sucked in to the carb(?)
in any case, do you think it would be a good plan to flush the fuel pump out or should I replace? It was full of oil also. EDIT; I sure don’t want to replace it. It looks expensive
Also, I picked up 5/32 inch and 5/16 inch pressure rated fuel line and fuel line zip ties.
I noticed that a lot of the fuel lines on these are factory formed, should I be too concerned about replacing with common line? Some of these corners have pretty tight bends, wondering if any kinks or collapsing in the lines could cause fuel pump to starve at WOT? And could that be detrimental?
Or am I overthinking things here.
