questions on 496 MAG / bravo III outdrive
osborne looney
girlfriends Daughter is looking at a 2003 266br 26' crownline with 496 mag and bravo III i do not too much experience or knowledge on these ? any problems one should look for ? thanks any info would be great
MarkSee
Re: questions on 496 MAG / bravo III outdrive
Always recommended to have a hull and mechanical surveys done ahead of time to make sure even the "cleanest looking" boat doesn't have some underlying problems.
Mark
TilliamWe
Banned
Corrosion on the outdrive, specifically the rear bearing carrier. Props have to be removed to see it, and it takes "special" wrenches (2 and 1/4 for the inner and 1 7/8 for the outer, I think).
It should have closed cooling, so make sure the coolant is full and that the boat runs the proper temp.
