matthewspahlinger
Thread starter- Joined
- Jul 17, 2008
- 4
i have a 1965 johnson 6hp. i got it running last night after some minor carb work. i only ran it for about 20 seconds because i didnt see any water coming out of the the exahaust/water output hole. does water instantly start coming out of the whole or does a thermostat have to open? if the water pump does need to be replaced, do i need to change oil in the lower unit? will there be oil as soon as i drop the unit or is it contained in a case? if anyone could shine some light on this process for me and ive also read how you have to rotate the prop until the little pins in the shaft lines up btu if someone could also explain this in more detail
thanks
matt
thanks
matt
