Lancer76
Thread starter- Joined
- Jul 23, 2017
- 121
1976 Chris Craft Lancer with same model year Mercruiser 233 and MC1 outdrive.
I have only been on the water twice in 2019 (short season in Maine). I noticed that the engine starts and runs great until I've been 3/4 throttle for 10-15 minutes or so. At that point, the engine drops out as if its run out of fuel. In fact, I believe the engine is running out of fuel due to a fouled fuel filter. The boat will restart right away and I can idle around for hours. When I push the throttle open again, the same thing happens.
Came home and removed the fuel filter, which I installed mid to late last season. The picture below shows some of the sediment that accumulated in the filter. Based on this, I am assuming I need to clean my tank. The other picture shows my tank. I have great access to it.
I've watched videos where folks have cleaned there tanks by recirculating fuel from the tank through a filter or two and then back into the tank. That seems like a reasonable idea when your access to the tank is via a pie plate access panel. My access is quite different.
I am thinking of siphoning the fuel left in my tank into my truck and fuel containers, I am then thinking of pulling the tank and cleaning it with some lower vapor pressure liquid (maybe diesel). I'll add the diesel and slosh it around to get the sediment into suspension, then pour it out of the tank through one of the holes. The spent diesel will be disposed of.
That's my thought but I'd like to hear other ideas. Thanks .
