Question
JerzJoe
Hi I have a Mercury 4.3l 190hp tks motor 2010. I noticed a black what appears to be a 50 amp reset button on top of motor by carb. There is a yellow wire coming off of this which is not
Connected to anything. Does that end go to the battery terminal ?? Thank you. Aee
Pics
Ayuh,...... Welcome Aboard,..... Where does the yellow wire go too,..??
I believe the screw it's hooked to is ground,....
achris
More fish than mountain goat
That's not yellow, it's yellow/green. It's not a standard BIA marine wire colour. That an earth wire in house wiring, and had no place on a boat! You'll find the wire isn't tinned, so will corroded very quickly. It's a negative for something, and I would find out what that something is and wire it in properly (hooking the negative up like that isn't 'properly'!) PO needs a solid kick in the pants!
Chris....
