Hello and thanks in advance for your help. I have just purchased my first bass boat and I don't really know what switches control what functions. It is a 1988 Astroglass 17.5 ft. 150 xp Evinrude.My first question is what does this pull type switch control under the drivers seat.
it has push to close and pull to open.
next if the yellow one is the bilge pump then what is the white one and does the hose marked connect to the live well?
. Next what does the knob under the key switch operate?
.and last for now this outlet is used for the bait tank up front. what keeps the water in this tank should there be a plug in the bottom of the tank to keep it from empting when the bow is up?
. Thanks again Is there a generic type book that may cover this type stuff you know like Chiltons or Haynes for cars.
it has push to close and pull to open.next if the yellow one is the bilge pump then what is the white one and does the hose marked connect to the live well?
