Question on Tabbing in the transom
jeffrey.bean
Installed two 3/4” Coosa boards with a layer of 1708 in between.
Should I do the tabbing first then lay a piece of 1708 to cover the transom?
As far as tabbing goes, is a 6” piece then a 10” sound good?
Thanks
kcassells
How ya doin. Never used coosa but the procedure would be the same.
2 layer over transom
2-3 tabbings , each beingf @ 3" wider than the other. So 6" wide first gives 3" overlay, next 6" wider. etc. ea. time covering @ 3" more either side.
I simply ran my glass for the transom 3" wide to tie to floor and sides. Then did tabbing. This is structurally one of the most imp. parts of the boat.
Everyone has a different spin on it.
You will also want to notch out the transom on the bottom where the drain goes and fill with pb now before glassing. Alot easier. This allows you to keep the transom wood being exposed later when you want to cut in your bilge drain.
jeffrey.bean
Doing good, thanks for asking.
Thanks for the run down, yeah, everyone seems to have a different approach when doing a transom.
No need to worry, no wood in the transom, all coosa, but I will pre coat the hole with epoxy before installing the drain tube.
Thanks again
