Question on Ficht 150's using portable gas tank for testing
Jbshoo
So I am nearing the point that I will be testing my pair of 150's tomorrow. Ive picked up a portable tank, plan is to use this to test while I continue to flush and change all racor filters on inboard tank.
Here are my questions that I could use some guidance on.
1. Where is the best/easiest place to plumb the portable tank into on the engine, they are Evinrude Ficht 150's.
2. Should I premix 50-1 with xd50? They have been sitting for 2 years, so I want to make sure they are getting lubrication. I've already refogged cylinders by removing plugs. They have been soaking for a day. Plugs are indexed and gapped .028.
3. Should I change/pump out old injection oil? Again been sitting a while. Not sure if it will hurt if I have that running along with premix?
I will be changing out plugs after initial run and will be putting back into break in mode for bit.
Thanks in advance.
Jeff
jimmbo
1) Disconnect the fuel line at either the tank, the Racor filter, or the fuel pump, and attach the portable tank there
2) Do not use premix, Ficht injects directly into the combustion chamber and any extra oils will mess up the amount of gas injected. Oil for the crankcase is injected either behind the throttle bodies or by oil ports on the crankcase.
3) Oils should go bad, they sit on dealers shelves for years. If it will make you feel better, shake the oil tank if you can
3.5) What would be you reasoning to use the breaking mode?
Faztbullet
1) Just attach fuel where original line attaches.....add a pint of oil to gas to 6 gallons to lube pintles in injectors
2) No ..don't work that way....
3) If the oil tanks are still hooked up, drain oil tank and refill with fresh oil. Disconnect line at pump and manually pump oil bulb till flushed. The reconnect and reprime oil system.
jimmbo
The Ficht fuel system already mixes oil into the fuel at about 300:1 to lubricate the injector pintles. No more oil is needed
Faztbullet
Meant half pint or 6-8 oz to 6 gallons...the extra oil will not hurt it ...
