Question... Mercruiser Alpha One bellows kit.. Where do the "O" rings go?
brodykmb
So I have fried my brain installing my bellows kit on my 96 Merc alpha one gen 2. I literally woke up dumb from the exhaustion of doing this job. I am not the most technical guy and this job took me through the ringer. Anyways, in my bellows kit there are 6 small 'o' rings and one larger ring that looks to fit the U Joint in some way.
Is there a diagram out there that I can see which will explain where these rings go? Also the U joint ring...... that goes on the bell housing side of the install? Does that larger ring fit in that bell housing slot on the inside then I pop my metal ring in there? Any help here would be appreciated..
thank you.
Don S
Re: Question... Mercruiser Alpha One bellows kit.. Where do the "O" rings go?
A lot depends on who's kit you bought as to what is in it. A part number of the kit will help, plus a pictures of the seals you have.
