Question for problem with Murcruiser 170 4.3
coolmethirteen
My engine over heated. Once it over heated with stream coming out of motor with looked like anti freeze substance seeping out as well. I turned the engine off so it could cool off. I started it up with the engine cover opened. it seemed to be running good with out over heating. The next day I started with the muffs on the lower intake with the water on. The water seemed to be flowing in and going through the motor. I thought everything was working correctly and normal, so I cleaned the engine off with engine cleaner and squirted the engine with a water hose and took the boat back out to the lake. It started alright and everything seemed fine. I cut the engine off once I tried to start it. It would not start. When I would turn the key, it sounded like a weak battery because the starter would attempt to start and make a clicking noise. Then eventually went down to only making the clicking noise. I called a towing service out to give me a boost. I found out that was an expensive decision. The tow service tried to give me a boost it did not work and the boat continued to make the clicking noise when I tried to start it with jumper cables attached. Maybe I wet something that was not suppose to be wet when it steamed up or when I wet it while cleaning the engine. What made it over heat.......should I replace that anti freeze substance that came out. I would appreciate if someone could tell me what might be going on and what I can do.
Faztbullet
Re: Trouble shoot problems murcruiser 170 4.3
Have you checked the coolant level ?
Randy J
Re: Question for problem with Murcruiser 170 4.3
pull spark plugs and see if water comes out , if does get the water out of cylenders read other posts lots of 4.3s had over heat and freeze issues this past winter i mean lots incl mine, so it sits good luck
Don S
Do you have a Mercruiser serial number? Not sure what engine you have for sure. No year, a 4.3 isn't 170hp, there is a model 170, but it's not a 4.3.
4.3 = V6 Chevy
170 = 3.7 Mercruiser 4 cylinder.
solar7647
Edit.....sorry I totally just wrote the trouble shooting instructions for a 3.7 not a 4.3:redface:
Don S
I merged both of your posts together in the same forum. Please do not post the same question in two different forums.
