FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Could you give here, or on the restoration thread, a rundown on repainting your hull. I know you sprayed it, but what paint did you use, how tough was it, how many coats, reducer, etc, etc.<br /> Thanks
Aaahhh paint. How I hate it.<br /> You are right I did shoot it. The rest is kind of straight forward. <br /> First I striped everything off the boat that would come off (you can tell when something has been painted around). Next was any body work. I had a few things I wanted to change so I had to use fiberglass, mat and finished it off with bondo. Then it is sand, sand, sand. If you do a poor sanding it will show. 220 grit wet sanding should be good enough as a finial sanding. <br /> I then got a paint sprayer from Home Depot and I had a compressor. Off to U/S Boat for paint. I used off the shelf Interflux paint thinned down with paint thinner so it would go through the sprayer (directions are on the can). The paint has a self leveling feature so it is hard to screw up. I shot it 4 times all on the same day so I did not have to wet sand between each coat but there is a fine line on when it is dry enough. If you shoot to early you will end up with runs. <br /> Not a expert by a long shot but it didnt turn out to bad for doing it in the back yard.
f_inscreenname<br /><br />was on your web site. liked it very much. i have a 1972 V24 Cuddy Seabird. If you are a histiry buff about fast boats etc you might find this <br />site interesting.http://www.schoellmarine.com/<br /><br />Harry has quite a history behind the scenes of many boat builders. i found it very interesting that he holds the patent on the conic hull. Running strakes are his as well.He is to be rumered Ray Hunts designer and colaberator on many projects but is not listed. My seabird is in fact credited by some publications to Hunt but is in fact harry's design. i think you will find his participation with Donzi, wellcraft, Glastron, Trojan, Fountain, Magnum, and he was also instramentsl in the Challenger Offshor racing circuit.
Thanks for the compliment and website tip. I will be out of town and out of touch (no Internet) for the next ten days but I will get into it when I get back. <br /> PS Did you stop by the "link" on my site (the red glowing one)? A lot of cool old boats there.
TO F_INSCREENNAME:<br /><br />Thanks for the info. Years of sunlight have turned my Wellcraft's red top side to a less- than- desireable shade of orange.<br /><br />I was going the route of a one-part poly Mega Gloss made by Blue Water Marine, and I was going to roll and brush it. But now I may spray it, if my brother will agree to let me use his garage.<br /><br />By the way, you boat looks great in the photos.
f,<br />Ditto on the above comments re your project. It looks stunning from the pix you have posted on your home page and the related info you have there is brilliant.<br />Congrats..<br />Peter
