question about replacing head
traben
What gaskets do I need to replace before i put my head back on an 3.0 mercruiser?
achris
More fish than mountain goat
Re: question about replacing head
Head gasket
Intake/exhaust manifold gasket
Exhaust elbow gasket (if the elbow was separated)
Thermostat housing gasket
Thermostat cover gasket
Rocker cover gasket
Carb gasket (if carb was removed from manifold)
That's all I can think of....
traben
I havent took the head off yet... so what are some of the things i need to do first
achris
That would depend on why you need to remove the head....
Fishermark
It's certainly a straight forward and easy job - if you are familiar with engines. So forgive me for pointing out some things that may be obvious... but since I don't know how much you know.... here's some other things you will need to do the job:
1. Good torque wrench.
2. A manual showing how to adjust the lifters.
3. For the riser / elbow gasket - you will want the OEM Quicksilver gasket -- not the green paper one that comes with some gasket sets.
While you are doing the job, it is a good time to replace the spark plugs and thermostat as well.
traben
i posted a different question about the same problem so i did a no=no here is the original problem posted here http://forums.iboats.com/showthread.php?t=466603
any input would be appreciated... i am now in the process of getting head bolts out and getting the head off to take it and get it checked...
