Question about Keeping tubes shining
Jobless Recovery
We've cleaned the tubes on our 'toon and am very happy with the results. We plan to get a nice shine on them using "Eagle" brand aluminum cleaner (as suggested by some other threads) however, I'm worried if I go through all this effort to get them shinning like a brand new penny, they will just re-tarnish once they get back into the lake. Any ideas on how I can keep them tubes "shinny-penny" looking for a long while? :rolleyes:
EGlideRider
Re: Question about Keeping tubes shining
I'm on my 4th pontoon boat in the last 25 years ago and I long ago concluded that shinny toons aren't worth all the work.
rickdb1boat
One quart did 2 coats (Recommended) on my 20' toon with some left over for touch-ups. Took less than an hour for each coat. I also did the transom and ladder while I was at it. You want to make sure not to miss any spots, cause you will see them later on as those areas will oxidize quickly. You can see where I missed the bottom of the transom in the pic below.
5150abf
Shark hide is what you want, the only problem is that it is a coating so if you dock your boat the bumpers can wear through the coating and that spot will start to oxidize but other than that it is a fabulous product.
Jobless Recovery
Thatwon't be a problem for us, we trailer ours. Thanks for info.
suprtrkr1974
jewler rouge and a high speed buffer. i done mine 2 years ago and have not touched them since and you can still shave in them
Mr Crabbs
I think someone else said that it 'boogers fish'.
I agree, for me, it's not worth the money or effort. No one has told me that sharkhide is worth the money and effort beyond shiney pontoons. I was told by my Tracker technicians to just clean them with cheap tire cleaner or mineral oil and a rag.
jeeperman
Are they bare naked or did you wax them or put something else on them to shield the aluminum from air?
suprtrkr1974
went back with a liquid aluminum polish as a sealer. can pick it up at any local truckstop works great
