Re: Question about hp rating
Here's what I found on the subject...
[Code of Federal Regulations]
[Title 33, Volume 2, Parts 125 to 199]
[Revised as of July 1, 1999]
From the U.S. Government Printing Office via GPO Access
[CITE: 33CFR183.53]
[Page 754-757]
NAVIGABLE WATERS
CHAPTER I--COAST GUARD, DEPARTMENT OF TRANSPORTATION (CONTINUED)
PART 183--BOATS AND ASSOCIATED EQUIPMENT--Table of Contents
Subpart D--Safe Powering
Sec. 183.53 Horsepower capacity.
The maximum horsepower capacity marked on a boat must not exceed the
horsepower capacity determined by the computation method discussed in
paragraph (a) of this section, or for certain qualifying boats, the
performance test method discussed in paragraph (b) of this section.
(a) The maximum horsepower capacity must be computed as follows:
[[Page 755]]
(1) Compute a factor by multiplying the boat length in feet by the
maximum transom width in feet excluding handles and other similar
fittings, attachments, and extensions. If the boat does not have a full
transom, the transom width is the broadest beam in the aftermost quarter
length of the boat.
(2) Locate horsepower capacity corresponding to the factor in Table
183.53.
(3) For a boat with a factor over 52.5, if the horsepower capacity
calculated in Table 183.53 is not an exact multiple of 5, it may be
raised to the next exact multiple of 5.
(4) For flat bottom hard chine boats with a factor of 52 or less,
the horsepower capacity must be reduced by one horsepower capacity
increment in Table 183.53....Table 183.53--Outboard Boat Horsepower Capacity
[Compute: Factor=Boat Length X Transom Width]
If factor (nearest integer) is...................... 0-35 36-39 40-42 43-45 46-52
Horsepower Capacity is.............................. 3 5 7.5 10 15
[Note: For flat bottom hard chine boats, with factor of 52 or less, reduce one capacity limit (e.g. 5 to 3)]
No remote steering, or less than 20" transom
Remote steering and at height
If factor is over 52.5 and the boat least 20" transom -------------------------------------------------
has height For flat bottom hard
chine boats For other boats
Horsepower capacity is (raise to (2 X Factor) -90....... (0.5 X Factor) -15..... (0.8 X Factor) -25
nearest multiple of 5).
I have a 1961 Lonestar Glass boat witha 20" Transom and the Plate says she's rated for a 70hp. I have a 40 hp on her and with 4 adults she's gunna be WAY underpowered. I will in the future be putting a 70' on her. I would think your boat could handle the 60 with no problems at all
