Question about gimble housing repair
Fishermark
Sorry for the long post, but here goes: I replaced the all bellows on my boat when I bought it last summer (It is a 1986 Sportcraft 242 walkaround with an alpha one outdrive). I noticed when I replaced the driveshaft bellows that the ring on the gimble housing was corroded and not much remained of the top of the ring - only about a half of an inch or so if memory serves me correctly. I applied the bellows adhesive and it seemed to hold fine.<br /><br />I am plagued with a leak around the transom area - it seems to be coming from the transom seal itself. On a previous post I mentioned applying some 5200 around the edges, but I still have leaks in the area. I am going to go ahead and pull the engine and entire transom assembly and put all new seals and gaskets in.<br /><br />My question pertains to the repair of the ring that the diveshaft bellows attaches to. New gimble housings are expensive to say the least. I found the following prduct online and wondered if anyone had any expericence good or bad with it:<br /><br />
<br /><br />
<br /><br />It apparently has a sleeve that is epoxied to the housing. It comes with a new bellows. Here is the link that describes it in more detail: repair kit <br /><br />I would love the input of those who work on these for a living! Thumbs up or down?
a.d.mobile
Re: Question about gimble housing repair
I dont know you should be able to pick up a used transom form E bay or a dealer lot of work if it dosent work. if you do it post up the result. bob
Fishermark
Yeah, I've looked at ebay and may go that route, but everything else on my housing is fine - there isn't an excessive amount of play, etc. so I would like to keep it if possible.
Fishermark
One last bump before giving up! If you haven't used this particular kit, what have you done? I've got to believe that this is a fairly common problem if you do much boating in salt water.
Buttanic
I think it would be an aceptable repair option. Just be sure that all corrosion and paint is removed from the area where the epoxy will be applied. That said I think the cost of the kit is about way too high. It would have to be less than $100 for me to consider it. Take your housing to a good aluminum fabrication shop and ask what they can do with it.<br /><br />Buttanic
Tufan
hi,<br />Epoxy doesnt really hold strongly there is a vibration of the drive shaft... (I bet you have a 3 blade prop on it?)<br />Try taking the piece to Aluminum work shop. They could add another ring with more meat with welding and then trim it again with a machine down to the specification. It is possible. However person REALLY needs to know what he is doing and it is a bad spot to work on. <br /><br />I tried this on my boat and it did work, for a short while than welding broke off... and there was the leak again. And of course each time you would have to change the bearing, not to mentions it is a pain to remove the drive unit...<br /><br />I highliy recommend changing the transom plate, it also comes ith all the power trim assembled and it is around $ 1000 - $ 1200 depending on your engine. Do not buy the used one.
Fishermark
Thanks for the thoughts .. I'm still not sure what I will do. I'll keep you updated. (Will know more when I actually remove the housing).
