Question about Gel coats
andyj9881
I just bought a 1987 Skeeter 16ft bass boat. I am a first time boat owner so I am pretty ignorant about how to fix a boat up. The gel coat is cloudy and flaking off. Is it possible for me redo the gel coat my self? Also, how improtant is the clear coat? I have heard that it is just cosmetic, but I wanted to ask you guys to be sure. Thanks for your time.
andyj9881
Re: Question about Gel coats
I have not doubt that the gel coat needs to be replaced. What does that entail? Do I need to bring it to a pro who will put it in a paint booth, or is there an over the counter alternative? I am kind of excited about doing it my self, just curious of what I would be getting my self into.
Chris1956
Gel coat is thickened polyester resin. It is to cover the cloth for a smooth appearance. Paint gives a higher grade finish, but gel coat is more durable and cheaper. High end yachts are painted with Imron or Awlgrip paint, to achieve the gloss and finish they desire.
ondarvr
Gel coat doesn't typically flake off, what happens on bass boats is when the clear gel coat starts to get dull and thin from chalking and/or buffing, the owner will have it clear coated with paint. Depending on the product used and the quality of the job, it can last a very long time, or only a year or two before flaking. Re-painting with a solid color is the best and easiest solution, it can be re-done with flake, but its a great deal of work
proshadetree
Ive been going to try it.Use a product called dura tech to thin.Spray gel with flake mixed or gell the use a flake buster to coat it.Then sevral layers to cover up the flake.Paint is easyest way but flaked gel is cool.Good luck.By the way gell needs to be sprayed out of a 2.5 tip gun.
andyj9881
Thank you guys for all of your input! This forum is an awesome place to get answers.
andyj9881
