Re: Question about fuel line
Easy way to check the bulb is to release line from motor (use a paperclip to keep line open if it's a quickfit connector), hold bulb upright with arrow on bulb at the top, and squeeze a few times into a can. You'll feel the bulb pulling fuel as it reinflates, and of course fuel will pour into the can.<br /><br />If it doesn't reinflate, the problem is between tank and bulb, and is usually a restricted vent or crud in the line somewhere. To check that out, remove line from tank. When you squeeze bulb again with line removed, if it reinflates, the problem's at the tank. If it doesn't reinflate, the problem's the bulb.<br /><br />If you have a filter/water separator between bulb and tank, this needs checking out also.
