Question about broken piece on outboard
Fox16
My motor is a 1996 48 special. What is the broken piece in the picture and is it important?617888-R1-021-9_008.jpg
R.Johnson
Re: Question about broken piece on outboard
That's a trim skeg to correct for hard steering pull in either direction.
Fox16
Thank You. My boat doesn't pull but i guess it should be fixed
bullbat
your really need to have it because it also absorbs corrosion to keep your engine from corroding
Fox16
I looked up skegs and they seem to be shaped like fins?
F_R
Honorary Supreme Mariner
You realize of course that the fin is busted off?
Fl_Richard
It is a skeg, looks like it was installed at quite an angle if the bolt hasnt been moved.... P/N 0340539. They arnt made of zinc so it's not a corrosion inhibitor.
5150abf
If you are gonna break something it may as well have a single bolt holding it on eh.
It isn't "important" as in the engine wil run without it but if it weren't needed they wouldn't have put it on.
Order a new one and once you get it you may need to adjust it a couple times to get the boat to run straight, normally without that the boat will pull to one side or the other from prop walk, the motor wants to go in the direction of prop rotation and that little fin counters that effect.
