Question about Breaker systems
grizzly1530
I have a 16 foot v bottom aluminum boat. I have done a lot of other work with it, but the wiring is something that I plan to do this spring. As of this moment, my boat has a 4 gang switch box connected to a fuse block (I'm not even sure I have the lingo right). I have lights, nav lights, depth finder, livewell pump, bilge pump, and a 12 volt plug for a phone charger to connect. I was looking at getting a breaker system since I'm upgrading the wiring. When I search for marine breaker panels, it seems like all of them come as switches with breakers in one, and with 2) 5 amp, 2) 10 amp, and 2) 15 amp breakers. I looked at my depth finder and livewell pump and they suggest 3 amp breakers/fuses. I feel like the only thing I would need a 15 amp breaker for is the 12 volt plug. Am I getting this correct? The livewell pump is a 500 gph pump, and the depth finder is a Humminbird 698 ci hd si. The nav lights and interior light I feel would draw about the same. The breaker panel I'm looking at is something like this. Can the breaker sizes be changed in these?
gm280
grizzy, I am not familiar with that particular switch setup, but I would assume there are replacement circuit breakers that you could change. With that said, I wouldn't go for the exact current usage for each circuit. For example, if your bilge pump draws 3 amps, I would go 4 or 5 amp with the breaker for that circuit. Same with other circuits. If your navigation lights add up to 2 amps, I would go with 3 or 4 amps. Never fuse or use breakers for the exact amount of current the circuit will use. Inrush currents can surge over the amount for a few seconds and blow a fuse or pop a breaker. So go just a little over the current rating for each circuit, but never over the wire capabilities. That way you protect both the circuit accessories and the wiring used in the circuit. JMHO!
kmarine
I agree. That you want a little wiggle room.. Most pannels will allow you to change out breakers. Most cigarette lighters use 20. Amp fuse, 15 is enough for a cell phone charger, but you may want to go larger incase you want to run an inverter for 120 volt toys.
grizzly1530
Awesome, thanks for the help guys! I had pretty much everything else down, but I just couldn't figure this breaker thing out. I was starting to think breakers were for big cabin cruisers only, haha.
