83vert
- Sep 10, 2009
- 394
I replaced my lower water pump assembly and bolter the two halves together. I figured why I had it on the bench I would make a pressure tester and just give it a quick test. Well, it turns out that the pressure drops to zero in about a minute. I used soapy water and could not find any bubbles but I thought I could smell gear oil by the prop-shaft. Even if I can locate where the leak is are the seals rather easy to change or do I have to take the outdrive apart? thanks
