DAVEKORAN25
Thread starter- Joined
- Nov 20, 2011
- 1
Yesterday I started this 1994 40HP Force outboard on this 15ft tri-hull I got last week from Craigslist. After some plug cleaning and starter fluid I got the engine to turn over and run (surprised me for a blind sale with little history on the motor) . Only problem is that I noticed right away in my barrel of clear water a sticky brown oil almost like foam that floated to the surface. Also I noticed some of the oil was inside the engine housing after running. Now noticing that it was brown I am not sure where it came from. And after 5 minutes of running the engine over temp buzzer came on. So question 1? Where did this oil come from. 2. Is this normal for an engine that had not run for a while? 3. Also I did not notice any water coming from the engine (where does it drian out from) is it all being despense from around the propeller like the exhaust.. Help? 4. I guess I am concerned about the brown oil in the barrel becuase there was a lot? Another problem I noticed is that my trim motor hums when switching DOWN but does nothing for raising UP. Any help with this? Any help appreciated.... Thanks..
