Q7, how much does it really weigh?
mnypitboat
OK maybe someone here knows. The link here says my boat weighs 4400lbs dry. Is this correct?? Seems really high to me. Does anyone know for sure what it weighs? I was thinking more like around 3500 or so tops.
lrdchaos
Re: Q7, how much does it really weigh?
I was thinking it was around 3100-3300 dry.
PrinceValium
the boat weighs 3010 lbs dry (according to tahoe boat website). Adding fuel to it and filling the 45 gallon tank (6.07 lbs/gallon) adds about 273 more pounds. So say it is 3,283 lbs. not including whatever you put in it of course.
BiggerDee
Plus extra weight if you have anything other than a 4.3. Had trouble pulling my '10 V-8 Q7SSi with my wife's Pacifica, so I sat down to do the calculations. I figured, based on indicated weights, that it should be slightly under the 3,500 max of the Pacifica, but it was having such a hard time dealing with the boat. Called and talked with Tracker and then called and talked to the folks at Mercury Marine. Found out that the dry weight didn't include the extra weight of the optional engine, fuel, oil, fluids, et cetera, or trailer (I hadn't even considered the trailer! DUH!). All told, with the boat (plus V-8) (3112 lbs), the tandem trailer (950lbs according to Tracker's numbers), gas (around 275lbs), and fluids (around 100lbs), I was almost at 4500, and that didn't even count ice, drinks, extinguishers, other boating needs/tools/et cetera (plus the number of folks in the tow vehicle itself and their combined weight). I am probably right at 5,000 with everything loaded and ready to pull to the water, just for the boat and contents alone. I say all of this for future reference for others browsing the forums to calculate everything (including the trailer!) when coming up with tow weight.
mnypitboat
Old thread, but your info is great for future users. My new boat (Monterey 214FS) must be much heavier than that because I can really feel it when accelerating. I could barely feel the Tahoe back there. Not to say our Trailblazer EXT V8 is struggling, I just feel it more than the Tahoe. Stopping is far easier and it has far less sway than then Tahoe, but acceleration has suffered. SOTP scale, I would guess this boat is about 400 to 500lbs more than the Tahoe. Which makes sense, because the owners manual indicates 3600lbs dry. Throw in all that other stuff, and 7 adults in the vehicle and we are probably pretty close to the max capacity, and max tow capacity of 7000lbs. I just cannot beleive how well this thing drags the boat so close to its capacity. It is getting near time to trade it in, so I think the next tow vehicle will probably be larger. ALthough the specs on the new Grand Cherokee is 7800lbs, so maybe that might be an option. The wife drives it as her DD, and she doesnt want a large SUV, so we shall see. Maybe I will just get her a little convertible, and buy an old 3/4 ton diesel.
