Q6 tx47 fishfinder pickup
maddog2112
Does anyone know where the transducer pickup for the 06 Q6 fish and ski is located? My fish finder only works in the simulator mode, and I suspect a problem with the transducer. I assume it is all factory, since it is the fish and ski.
mccownk
Re: Q6 tx47 fishfinder pickup
Mine is a through hull mount located in the engine compartment
maddog2112
I believe mine is thru the hull also, but cannot physically see it in the compartment. If anyone has actually seen it, please give me a clue where to look. Thanks
rdhawk1950
Sorry but the pic does not depict a factory install transducer. The factory trancducer will be behind the bilge pump below the aft motor toward the hull drain, it will be a surface fount and not a thru hull.If there is a dash mount as well as a bow mount there wlii be 2 transducers.
maddog2112
Mine definately is not where yours is mccownk. I`ll check where rdhawk has suggested . Thanks for all the info.:D
mccownk
Well... at least now you know what it looks like.
