Q4 trailer grease gun \ winterizing question.
Mordekai
Hi all,
With winter coming, winterizing task is here, what grease gun do you guys got/have to pump in fresh grease into our ez lube spindle?
Also with the draining of the block. Do you guys just pull the blue tube and let it drain, any other drainage that has to be done?
Do you guys also drain your drive lube from the outdrive and just pour fresh ones from the top or where?
thanks
yourboatmyboat
Re: Q4 trailer grease gun \ winterizing question.
No need to drain the lube oil. As for your block drain just pulling the blue tube is not enough. The tube only slides up and down the hoses. At the block where the hoses connect there will be a grey push lock. Press the grey plastic and pull hoses off. Refer to your owners manual for all up keep and maintaince.
Mordekai
I have both the alpha one gen 2 service manual and the GM 3.0L service manual,
The for the service engine, it only says to pull the blue tube and nothing else, that's why I wanted to check...
