PWC trailer for Jon Boat, with added tongue length?
DocTide
So I am looking to get another 12ft fiberglass skiff, weighing in at about 220# just the boat. I had the same boat awhile back with the CE Smith multisport trailer, that had a 900# capacity, and it did a great job- BUT the trailer itself was only 11ft long total length. This made my tires get wet at the ramps every time, and with a 4cyl, 5-speed manual Ford Ranger, I really want to avoid that sketchy situation.
My question is, I looked on Continentals site and they have a jon boat trailer (JB127) that is rated at 900# capacity, and is 14ft total length. They also have a jetski trailer that is (WC2E9) 13ft total length, with 900# capacity. The cost difference between the two is almost $275... So I am leaning towards the WC2E9, and perhaps adding a swing tongue and a 1.5ft extra length to it. That extra 2+ ft on total length for me is the difference between getting my tires into the water usually so I really need it. Is this a bad idea? The boat/motor/gear for this boat on trailer is probably less than 450# total. I am looking to get a 15HP 2-stroke (~80lbs), and a cooler + gas would probably only add another 60lbs... Is it bad to have a lightweight boat like this on an extended trailer, would I run into any problems while trailering?
The difference to me seems small between the trailers new (1ft less in length, 2in less in width) to warrant the extra $275, and this is why I am asking here. I already have the extra 2x3 length to extend the trailer as I was going to do it previously, and would only need the swing tongue.
Let me know your thoughts please.
smokeonthewater
Since you are looking to purchase a new trailer you should be asking the manufacturer this question first... Heck they MIGHT even let you custom order your new trailer.
muskyfins
Three things come to mind:
1. Make sure you have enough tongue weight when setting up the rig.
2. You might want to add some of those "side guides" Like you see on some of the deep vee fishing rigs. This might help prevent it from walking from one side to the other on the road.
3. Make sure you adequately strap the boat to the trailer.
PS-you might want an extra long winch strap too.
