- Mar 8, 2009
- 43,594
Have a PWC lifting sling I bought several years ago. Its a Erickson (Made in China) rated at 1000 lbs and says right on it "use at your own risk". Did not notice the label when I bought it, but did understand the rating.
Have lifted using it numerous times. Used it today, lift a bit and go back down re-position and lift again until its balanced even. The PWC is about 4 inches off the trailer and one side of the webbing tears loose. It tore right at the stitching
Aqua cart makes one rated at 2000 lbs $400 and ProHoist rated 1500 $170
Thinking about using one of my Kinedyne ratchet straps and replace the strapping with it. Just need a way to attach (don't have a sewing machine large enough)
What are others using
