Pump issue
Bowhunter3125
Git an 84' 50 hp I just installed in my boat. Hasn't running almost 6 years but I got it to fire. All seems well except that it wont pee in idle in neutral. The moment I throttle up it will pee and if I put it into gear, even at idle it will pee. Is this normal? I was told it was normal because if a thermostat. New to this size of motor.
As soon as the motor starts it should pee !!------Install a new impeller now.----Thermostat has nothing to do with the pee stream at all.
Bowhunter3125
Ok, have to find someone local to do it for me. Seals may need replaced as well, got oil coming out the prop
A 84 Mercury 50 HP may not even have a thermostat.------Impeller is easy to replace if you want to learn to save $100 / hr charges.
Bowhunter3125
So I tried to remove the lower unit, removed all 5 bolts, drops about 1/4" then it stops. Friend suggested it may be the drive shaft sticking but he was unsure how to proceed.
read the factory service manual, it will tell you the procedure and why it only drops 1/4"
you need the drive in forward to allow the shift linkage to come apart. that is covered
Bowhunter3125
So, found a couple videos and articles on line, all said the same thing, the grease on the drive shaft splines gets old and hardens, almost like a glue. Everyone has had to turn the motor upside down and spends days spraying degreaser down the shaft and let it soybean away at the grease.
Don't think so.--------If it came down 1/4" the driveshaft is not stuck / seized.--------Perhaps some plastic wedges and a bump from a small mallet will get it apart.-----Forward / neutral / reverse does not matter either.
Bowhunter3125
i am gonna make some wood wedges, that way i know the wood will go before i break the housing.
Bowhunter3125
Still ain't got the lower unit off. But I was advised my mark at Mark's mercury in Salem that because this motor was used in saltwater, the shaft is more then likely rusted in. He suggested to drill a 1 inch hole in the middle housing just down from the head unit then spray the shaft several times a day with pb blaster. May take a week to get it lose.
Put the lower unit back up to within 1/8" of the exhaust housing.----Couple of nuts will hold it in place.-----Put the muffs on and start it up.----Vibration / shaking will likely loosen the rust.------Run for 5 minutes.
