paradise#1
Thread starter- Joined
- Mar 7, 2017
- 1
Hello All,
I'm new to the forum and I have a couple of questions. First the basics, I have a 2004 Regal 2860 Commodore with twin 4.3L Mercruisers with around 400 hrs on them. Last year before the season started in April, I had both outdrives, Bravo 3's, rebuilt, almost $10K.
I also put in new Gimbal bearing, shift cables, bellows, sanded and repainted the transom plate, bell housing and Gimbal ring. I put all new bushings and sleeves in everything I painted. Let's just say that everything from the transom plate out was pretty much new. This year its seems that I will have to pull the starboard engine to replace a flywheel. I plan to pull the motor myself, and I'm pretty mechanical, so I am pretty confident about doing it. Just looking at it, it looks like all I have to do is remove the lower unit, undo the wire connection, fuel line, raw water inlet for cooling and the two motor mounts and lift it out. Is there any underlying problems or anything I might be missing to pull that motor? And while I have it out, is there anything else I should repair/check etc.?
Thanks for your help
