joshdashnaw
Thread starter- Joined
- May 5, 2007
- 63
I've gone through and read some threads on lower units, but still have some questions. Do I need to drain any gear oil out before I pull it off or is it a sealed inside there. I should probably change the gear oil either way. I noticed three screw on the unit. A lower that looks like where I would drain it, and two up top one saying vent and one fill. Is there anything else I should know about changing the oil. I pulling the lower unit to look at the water pump. I plan on changing the impeller, but what else should I look for to replace. What to look for to tell if the whole pump itself needs replacing. I have gotten a lot done with the help of all of you, and now I'm almost ready to take the boat out.
