Pulling 1994 OMC Cobra Efi 5.8 and OMC Cobra sx Outdrive
sudzup1
Hey all,
I just bought a 1994 Four Winns Sindowner 215, It needs a new Gimbal Housing Assembly. Everything I've read says to pull the motor in which case the outdrive comes off for that. I'm ordering a new gimbal bearing all out drive gaskets and new bellows. Can anyone tell me anything else I'll need to replace while I have everything apart. What gear does it need to be in before I pull the outdrive? Also part numbers would be great on the gasket kit , bearing ect... I'm in the process of ordering the bearing installer and puller/alignment tools.
Thank you
Horigan
Why do you think you need to replace the gimbal housing? Is the gimbal bearing area damaged?
Pulling the drive is relatively easy. See link below.
sudzup1
Where the drive shaft bellow mounts is broken, the ring is cracked. I am getting ready to pull the motor to do repairs. I was wnting to try and get part number for everything and was hoping someone knew of a kit I could buy with most of gaskets and bearing included
