FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Is there a repair system besides Hellicoils to repair pulled threads on a crank case ? If so is it an easy fix or need to send crankcase to a machine shop to do the work right ? Please advise.
Good to know that, will check link, seems that one or two head bolts threads on powerhead will be shot dead on next head gasket change due to salt seizure with consequent broken bolt and its heat removal done on last restoration, so planing way ahead of time to have those handy. Will check Amazon. Thanks both.
Timesert kits are nice and costly, but for the non experienced seems bit complicated to install, too much tooling, have worked with Heli Coils before. This is the OEM cylinder head bolt with measurements.
Was wondering if this repair kit would be appropriate to fit most of the 22 mm threaded extension ?
Assume a M10 bolt is a 8.0mm diam bolt as in pic, right ?
1.5 ? stands for inches/centimeters
Please advise..
Would you say that the posted bolt pic corresponds to a fine or coarse thread ? 1.5 stands for 1.5 cm or 15 mm Heli Coils, what if too short to properly screw in a 22 mm bolt thread ? Will bolt be possible to torque it right to 30 NM cyl head specs ?
