Greetings all, I have a 62' Evinrude outboard that I was attempting the change the lower unit oil on. Unfortunately, I removed the wrong screw and cannot get it to go back in. The screw is located in the drivers side of the lower unit at the same level as the real drain plug. The screw is about an inch long and tipped with a smooth surface before the threads. Something inside the motor has moved down and blocked the entrance? I can put a screwdriver inside and move it back up but it falls back down when I remove the tool. Surely there is a way to get this thing back in. Any advice for the new boating idiot? I can send a picture if it would help. Thanks in advance, I hope
