Pulled the trigger on a Minnkota 80lb trolling motor.......
newbie4life
How do I charge the batteries? It's a 24v setup...... do I disconnect the batteries from the trolling motor, and charge each one individually?
jtexas
Re: Pulled the trigger on a Minnkota 80lb trolling motor.......
not necessary to disconnect 'em, but unless you have a 2-bank charger, you'll have to charge 'em one at a time.
Barnacle_Bill
Do yourself a big favor and get an on-board charger. Just plug it in after every use and forget it until time to go again. You got a good TM!
newbie4life
Thanks for the help, guys.
I bought a bigger TM than was recommended -- from what I hear, you don't want to buy one that's too small.
However, then I bought batteries. If I didn't overspend on the TM, then throw in the batteries, and you just about have cause for divorce.
Now, it looks like I need a 2 bank charger. I sense some couch nights a comin'. I don't mind the couch that much..... it's kinda like campin'.
Ideally, an automatic charger would be perfect..... but what about a 2 amp trickle charger? How long will it take to charge these 750 amp batteries? If I do connect the chargers, won't I have to take off the jumper between the negative of the #1 battery, and the positive of the #2?
Thanks for the help -- again.
jtexas
no, the jumper can stay in place.
750 is the CCA, right? to estimate the recharge time, you need the AH (amp hours). For example, a typical 100AH battery 70% discharged would take 35 hours to recharge at 2 amps.
Rule of thumb, choose a charger setting that is less than 25% of the AH rating and less than 10% of the RC rating.
An unregulated 2amp trickle charger might be ok for overnight, but don't leave it on unattended 24/7.
