pull starter rope recoil
Marka1121
the starter pull rope for my 1970 evinrude outboard does not recoil after pulling, and ideas
JB
Re: pull starter rope recoil
Yes, Mark.<br /><br />The best idea is to get a manual. It will show/tell you how to service the recoil starter.<br /><br />Click on Repair Manuals at the bottom of this page.<br /><br />Good luck. :)
apexfishman
Mark,<br /><br />I have the same problem with the starter not recoiling. Were you able to get yours fixed? <br /><br />If so, how hard/easy a repair was it?<br /><br />MW
alcan
Repairing recoil starters most of ther time is no real big deal for the person who knows what he is doing and has done it a time or two. Because these are safety issues involved and trying to intstruct someone without the aid of pictures can be a nightmare. The best thing to do here is follow JB's advice and aquire a manual. You may find a copy at your local library. If not the cost of purchessing one will be paid for just fixing your rercoil starter.
D
DJ
Guest
Good advice on getting a hold of a manual.<br /><br />Many different recoils have different tricks used to cage the spring. These things can be extemely exaspirating, if you don't know the tricks.<br /><br />Kind of like trying to herd cats. :eek:
steviecops
I had the same problem on a 1984 Johnson 9.9 a few years back.<br /><br />By following the manual, I was able to dismantle the mechanism without any problems, and I am a complete novice with outboard engines.<br /><br />My recoil spring had come out of its fixing slot and I was able to bend the slot back into shape and re-fix the spring. Apparently, the reason it had happened was that the rope was too short. A new rope is quite long to prevent it from being pulled all the way out.
