Re: Pull starter on Chrysler 6HP.
Franki --<br /><br />My boat is a 25 foot Chris Craft cabin cruiser (1977 Catalina model). The auxiliary motor has been mounted on the port side, although I'm planning to mount it in the middle this spring or summer when I put on a swim platform. The 10hp Chrysler Sailor I have is a 1976 or '77 model (not sure) with electronic ignition (Chrysler's Magnapower III). If the CD module goes out, I'll need to scramble a little, but the motor has run well. Both the Chrysler and the 1990 Evinrude I sometimes use are sailboat models with high-thrust props (and the heavy duty legs -- particularly the Chrysler Sailor, which was built with a very heavy lower unit). I think the additional thrust is probably more of a factor in control than horsepower. Having said that, I'm converting to a regular leg and prop this year on the Chrysler to try and save some weight (same length, just not the heavy construction). Based on my experience with the motor, I believe it still will have enough power/thrust to handle the boat under most conditions. For me, raising and lowering the motor as well as ease in getting it on and off the boat are factors. (The weight difference between a 10 and a 15 is probably not that great, by the way, if the 15 seems preferable.) <br /><br />For trolling, I like the idea of getting the right boat speed without having to idle the outboard down too low -- better if the motor can run at slightly higher rpms, so a smaller hp is not a problem there. At higher rpms, they are likely to cool better, charge better, and burn cleaner. I like the electric start, by the way, with an alternator.<br /><br />The 6hp powerhead should come off fairly easily. Take care to disconnect all linkages -- watch out for the choke knob link at the carb. Mine is held by a little stainless clip that will break if stressed -- difficult to replace. You might be able to reuse the existing gasket under the powerhead, although new ones are available through Mercury dealers, and are not expensive.<br /><br />would like to hear how it works out....<br /><br /> Curt
