Pull Cord Won't Retract!!
dbd22
Can someone tell me if I need to replace the spring or can I get it :confused:to retract?
1978 Evinrude 9.9 Never had a problem til now!
I appreciate any advise!
QC
Re: Pull Cord Won't Retract!!
Hey dbd, welcome to iboats!!! You'll get a lot more help, and probably quicker, if you repost this in the Johnson/Evinrude section below vvvvvv ;)
rentalguy1
Probably just need to pull the cap and rewind/lube the spring.
Boatist
It probably means the spring has come loose or the end is broken off. If you have the manual very easy to take off and check and repair, If your need to replace still very easy. Either way make sure you read the saftey information as if you let the spring get loose can cut hands. Also possible the pull cord if frayed and getting caught.
