Lou C
Thread starter- Joined
- Nov 10, 2002
- 14,524
Gas fumes are a significant hazard for gas inboard owners. In addition to sniffing before starting up, proper fueling practices and use of the blower, it's a good idea to have a gas vapor detector installed on your boat. I went one step further, I got a hand held combustible gas detector (detects gasoline, propane, etc) to check all around the gas tank, around the carb, fuel pump and fuel lines. I tested it with a gas can and a gas stove and this thing WORKS! Lucky I found no leaks in the boat, the alu tank is 38 years old!
Especially useful if you have done work on the fuel system recently like a new tank, fuel hoses, pump or carb rebuild.... remember fuel vapors are heavier than air, check way down at the bottom of the bilge.
