PS2 internal clock
brother chris
My PS2's internal clock seems to reset everytime I turn the PS2 on.<br />It resets to Jan 1, 2000. :confused: <br />Does anyone have any idea how I can fix this? <br />Thanks,<br />B.C.
Pony
Re: PS2 internal clock
Are you turning it on from the button on the front of the unit? Or the Power switch on the back?<br /><br />1.If from the front, then I am unsure of what the issue could be.<br /><br />2.If from the back, that will always happen. Just like unplugging a TV, the times always resets. If you want the time and date to be accurate you have to keep the unit in Standby, not turning power to the unit off completely.
brother chris
I am turning it off/on from the back of the unit. <br />But the thing is....it always has kept time, accurately, until last week. <br />This affects my games, as I have to reset the date in order to play certain events in certain games. <br />It's a real pain.
Pony
Thats really odd, everytime I have had turned mine off in the back I have has to reset the clock.<br /><br />Why not just keep it in standby?
brother chris
Well, guess I will have to keep it on stand-by if I cannot figure out why it stopped telling time.<br />Thanks .Pony.
briannh1234
On some older motherboard's you need to replace the battery. It's mounted on the Motherboard in a round holder. When you pull the battery out it is about the size of a quarter.<br /><br />Radio Shack can fix you up with a replacement.
brother chris
Cool, thanks briannh.<br />I will take it look.<br />B.C.
Xcusme
Yup, sounds like it's time for a CMOS battery. Simple fix,Radio Shack has the battery. Be sure to pull the A/C line cord out before you change cards,battery etc. <br /><br />You might want to go into your Bios and write down the settings for each menu option, it's a pain, but can save you a bunch of time if all of your settings are lost.
