I have a 1988 ProV 150 G, code 6J9 L, I was driving the boat at WOT and the engine just died, like someone turned off the key. Tried restarting, engine just spins over, no attempt to start. Using my Seloc Yamaha Outboard manual I started checking things. I have 500,000 ohms on the wihite wire at the control box form the kill switch. I pulled the control box, the unit in the CDI enclosure, my resistance readings are nowhere close to those published in the Seloc manual.
From reading other threads on the Yamaha engines I assume the charging coil powers the CDI and the pulser coils control timing and firing of the ignition coils through the CDI.
I will perform the resistance checks on the pulser coils and charging coil and add that information later on.
I used a High energy spark plug tester, the spark plug has a clip so it can be clipped to a ground and a spark plug wire connected to it. There was no spark, but the CDI may not generate the same high voltage field as my GM van does.
