ProV 200 won't rev above idle
mn.boomer
I put my boat in the water this weekend, and had trouble less than 100 yards from the launch. The motor was running on muffs after being winterized. In the lake, it started up fine, water was coming out and I pushed the throttle down and it bogged, didn't want to accelerate and then died. The engine did not seem to want to rev above idle RPMs at all. Any suggestions as for potential problems or things to check?
99yam40
Re: ProV 200 won't rev above idle
post model #
sounds like fuel system needs attention , but never hurts to check compression,spark and timing.
Test fuel pressure /vacuum and clean/ replace filters
then it is carbs if they are on this motor
