Matthew A.
Thread starter- Joined
- Jan 24, 2006
- 232
I recently replaced all of the lowerunit bearings and seals. I was able to adjust the end play of the propshaft to about .002" to .003" by installing a forward gear thrust washer of correct thickness. With use this play has increased to .007" +/- .001". However, the propshafts side to side play seems to be increasing with use. At time of rebuild, the side to side play if measured from end of shaft at prop nut threads, was probably .015" to .020" in either direction. Currently side to side play maybe more then double. I realize this increase could be due to improper propshaft diameter @ bearing contact surfaces. However, could excessive wear of the bronze sleeve that is pressed in the forward gear also cause side to side play of the prop shaft?
Lower unit is single exhaust, single drive shaft, engine model number 856X8B
Hours on lower unit= less then 70 hours
