Props
rigger101
I have a 1968 20hp Johnson outboard Modle FD-22A. Will a prop for a 1969 20hp fit this motor.I can't seem to find one for a 68 but there are plenty for the 69. Thanks
OBJ
Re: Props
Welcome to iboats forums rigger....<br /><br />Props otta swap with no problem. Near identical motors.<br /><br />Good Luck.
rickdb1boat
Re: Props
I'm seeing that the same prop will fit from 1957-1973 if it's a pin drive. Is it splined or pin drive? If all else fails, call a prop shop. they will know for sure...
