props
Kevin Hutchinson
I have an oldler 60 horse evinrude I lost the props and all that is left id the shaft I would like to replace with a new one but haveing some trouble got a model number of 60442s and serial number c418075 also says on the plate 4000 to 5000 rpm
60 hp @4500 rpm.
steelespike
Re: props
I found a 60432 64 60 hp standard prop listed in the Evinrude brochure is 9 1/2" X 10" diameter X pitch, 20:23 gear ratio_Of course the final prop size would depend on the application. What size/weight boat is it on?Do you have any performance specs before prop was lost.If you can give us detail info on the boat hwsiii has a program he may be able to pin down a prop for you.Other wise start with the standard prop and get us the max rpm and speed with it.Look for hwsiii posts you'll find his spec Qs list.
