props for outboard johnson
flpyd p
Iam running a michigan pj81 prop I wonder if I can change prop to get more speed What size prop should I be using
wilde1j
Re: props for outboard johnson
You might let us know what motor, boat and what the WOT RPM is with the current prop.
steelespike
Welcome, please read the stickies at the top opf the page and get as much info to us as possible.
Prop size should be near the base of the blades or under the prop nut.
