Dave_Noffsinger
Thread starter- Joined
- Sep 4, 2007
- 12
This is the first time I've ever had to replace a prop and I'm feeling a bit lost and confused with it. I did read the FAQ's on props but I'm still not sure what I need to get.
I've got a 1985 Johnson V4 90hp on a 1985 15' Glasstream Hydroski. It has an aluminum prop on it now which needs to be replaced. My buddy was driving it this past weekend and clipped a stump which took a chunk out of one of the blades. I'm assuming it's a stock prop and that would be fine as far as replacing it goes. I mostly use the boat for fishing and some tubing/skiing. I'm not sure what the recomended wide open RPM range for this motor is.
If anyone could give me some advice and direction I should go with it that would much appreciated. Also, I've been looking for some places that sell used props if anyone knows a good place to check.
Thanks,
Dave
Thanks,
Dave
